HD-5 on Wichita Craigslist
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Topic: HD-5 on Wichita Craigslist
    Posted: 24 Feb 2011 at 4:47pm
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 5:07pm
Drot loader , first I have seen on a HD5 rather than tracto-motive, now with oil tank behind seat it would be a little cramped for operator. Few guards missing and such from undercarrage but price is in reason.
 Sprocket replacement can be a chore unless you have done it before, a weld on ring, installed by professional would be the cheap and easy way if you have never done undercarrage work before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 6:13pm
Might have to think about it as it is just down the road from me, comparatively speaking. But then there is a D grader that I could drive home, it is so close, and I haven't jumped on that either... still have a 44 C I have to get out of the shop...
Miles Gray (CO/KS)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 6:41pm
What is the weight of a HD5G?  Can I safely haul it on a single wheel two axle gooseneck?
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 10:05am
I thought that they run about 15k lbs. all dressed up.
1961 H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 10:44am
A little heavy for my trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 10:59am
A ggod 15,000 and on 2 axel you would have to transfer lot of weight to tow viehicle, then wonder if it was bridged right.
 I have a tri-axel (single wheel) I hauled my HD5 and FD5 on , hauled my D6-9U on it also but may have been over on axels then as had the mobile home type under it with 14.5 tires. Now have 3 - 7,000 axels with 245 X16 tires but use dump truck for towing.
