HD-5 on Wichita Craigslist |
MilesGray (CO/KS)
Topic: HD-5 on Wichita CraigslistPosted: 24 Feb 2011 at 4:47pm |
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42208 |
Posted: 24 Feb 2011 at 5:07pm |
Drot loader , first I have seen on a HD5 rather than tracto-motive, now with oil tank behind seat it would be a little cramped for operator. Few guards missing and such from undercarrage but price is in reason.
Sprocket replacement can be a chore unless you have done it before, a weld on ring, installed by professional would be the cheap and easy way if you have never done undercarrage work before.
MilesGray (CO/KS)
Posted: 24 Feb 2011 at 6:13pm |
Might have to think about it as it is just down the road from me, comparatively speaking. But then there is a D grader that I could drive home, it is so close, and I haven't jumped on that either... still have a 44 C I have to get out of the shop...
Miles Gray (CO/KS)
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35344 |
Posted: 24 Feb 2011 at 6:41pm |
What is the weight of a HD5G? Can I safely haul it on a single wheel two axle gooseneck?
Kipn
Joined: 12 Sep 2009 Location: Tewksbury, Ma Points: 800 |
Posted: 25 Feb 2011 at 10:05am |
I thought that they run about 15k lbs. all dressed up.
1961 H3
DMiller
Posted: 25 Feb 2011 at 10:44am |
A little heavy for my trailer.
Coke-in-MN
Posted: 25 Feb 2011 at 10:59am |
A ggod 15,000 and on 2 axel you would have to transfer lot of weight to tow viehicle, then wonder if it was bridged right.
I have a tri-axel (single wheel) I hauled my HD5 and FD5 on , hauled my D6-9U on it also but may have been over on axels then as had the mobile home type under it with 14.5 tires. Now have 3 - 7,000 axels with 245 X16 tires but use dump truck for towing.
