HD5 Master Link Question
Message Reverse Sort Order
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: HD5 Master Link Question
    Posted: 03 Sep 2018 at 5:51pm
Pin size is the Same for a John Deere 350, stock size spacers are available at track shop.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 5:23pm
The spacer washer you mentioned in master link is conforming to the shape of a link to index into track - then it also is shimmed to have the right clearance for width .
 I had a set of HD5B track that I put on a HD5G and had to add 2 links on each chain - I also had A set of tracks from a HD6 I needed to shorten for a HD5B
 Best to have a track shop do the pressing and install new master pin and inside -
bushing to match
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 7:01pm
The chain was assembled one link at a time. To add 4 links take them apart and put them back one link at a time same as making a chain from parts. If you add the 4 links at the point where your present master pin is then the final assembly is easier.
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 8:54am
I have to add a section 4 links to my new replacement track chain. None of the links are master links and I really don't want to try spreading the links to put them together. Can I grind off the lip on the link bushing and use spacer washers on the link it indexes in to? If so, have any of you made the washers out of a piece of heavy wall pipe?
This page was generated in 0.227 seconds.
