HD5 lift cylinder packing |
moco27
Topic: HD5 lift cylinder packingPosted: 01 Aug 2021 at 7:31pm |
I have an HD5 with a blown seal in a bucket lift cylinder that I need to repack. What size is the packing and where is the best place to get it?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 01 Aug 2021 at 8:43pm |
It's a V ring packing that is split ring , one lower backup ring and I believe 5 v rings .
Measure the shaft diameter and can get it from a hydraulic shop or try McMaster Carr Save old rings as as packing wears you can add a additional ring to get more compression on present rings . To get a sample and size - remove the 2 bolts from gland - raise brass gland from cylinder - then fish out old packing rings with a packing ring hook - ( small corkscrew ) |
gemdozer
Posted: 02 Aug 2021 at 6:31pm |
I check tomorrow but should have the cylinder packings for HD5
moco27
Posted: 03 Aug 2021 at 2:46pm |
the packing that was in there was an impregnated rope but the rope comes in different sizes and the place where I get it said they need to know the size. The packing that is in there now may have been someone improvising but I have no way of knowing.
gemdozer
Posted: 03 Aug 2021 at 7:15pm |
I check todays and have some packing but not sure they look for the rod approximatif 2 inchs but have no parts number on and should have maybe 25 on racking in box
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 03 Aug 2021 at 7:20pm |
i just redid the cylinders on my early hd6 a year ago. local hydraulic shop got me all the v ring packings and seals no problem.
nella(Pa)
Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3145 |
Posted: 03 Aug 2021 at 7:55pm |
Coke-in-MN
Posted: 04 Aug 2021 at 12:56am |
It's a V ring style lowest one is a flat one side a V on top it's the first ring that shapes the other 5 rings above it to keep shape for the upper gland that is also V shaped
Sounds like someone added rope style to take up room and the expand old packing enough to keep the leaking small . i did that on a telescoping cylinder on one dump truck until I got new V rings to install . That 2" mentioned above sounds about right size |
