HD5 injector question |
random_farmhick
Topic: HD5 injector questionPosted: 24 Nov 2025 at 4:34pm |
On my HD5 I was doing a bunch of work, and decided since I was so close I would pull the valve cover and check the valve lash and see what's there for injectors. Now I don't know what to do, haha. Valves were pretty close to the book, so fine tuned those, checked injector timing and its WAY off according to the book, BUT still in a spec that is a detroit spec... According to the book it should be 1.484, and it's actually at 1.460, but it also has 70 yellow tag injectors in it, which the book calls for 60 injectors I think. Google search shows 1.460 is what many people set 70 injectors at. So I don't know what to do... It wont get any easier to change it unless I pull them for some reason. It doesn't start TOO bad, but does smoke a little more white than I'd like to see, especially until it warms up. If it was yours, what would you set them at? The only other real detroit experience I've had was a silver 6-71tta in my brigadier dump truck that had 7a77 injectors in it, and that's what it called for so that's what I went back with.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34646 |
Posted: 24 Nov 2025 at 5:04pm |
Set to 1.460, otherwise will at full throttle overfuel.
random_farmhick
Posted: 24 Nov 2025 at 5:22pm |
Is that the difference in the 60 to the 70 size injectors? Or just in general? |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4783 |
Posted: 25 Nov 2025 at 11:37am |
Many of the DD engines in the crawler here had bigger injectors for few extra ponys. Have cousin farming with AC HD 9's. They have much newer heads from V8 DD with extra valves, and bigger injectors for major horsepower increase.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8702 |
Posted: 25 Nov 2025 at 2:22pm |
My 8V92TTA was at 1.484 with 9A90's? Think my beginner 6-71 was same with N65's. PO said had later advanced cam. Too much time passed to remember it all.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42070 |
Posted: 17 hours 25 minutes ago at 12:31am |
HV7 is in the 2-71 as stock injectors
DMiller
Posted: 13 hours 50 minutes ago at 4:06am |
That was a long dormant braincell fire off. Knew that as was taught that in the 1970s and cannot remember who or why. Except was to limit overfuel piston coking in the 71 series smaller engines as opposed to the V or inline six series with larger injectors. Believe came from a mechanic at Western Diesel when I was gaining my DD 71 series overhaul cert. around 1977.
Edit: Also had some pertinence of Trunk type vs Crosshead piston styles. Smaller engines tended to be Trunk type. Edited by DMiller - 13 hours 45 minutes ago at 4:11am |
