HD5 front idler (wanted)
Bergie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bergie Quote  Post ReplyReply Direct Link To This Post Topic: HD5 front idler (wanted)
    Posted: 10 Aug 2014 at 8:16pm
Has anybody here repaired the center section of an idler? Wondering the best method is to fix these. If you have a decent one for sale, please let me know.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2014 at 12:04pm
HD5 and HD6 use the same front idler - you can have them welded up by track shop of everything else is good - bearings - seals - axle shaft.
 They use submerged arc welding while unit is in jig to get even weld on wheel
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 11:07am
You should speak on this site to dadsdozer he should still have a good used idler and me am still have some but am to far from you, am near MONTREAL CANADA  and am't shipping parts over 60 lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 12:13pm
In Duluth MN try Northern Engine , can try Northern Tractor In Osseo MN , also Thill Track and Tractor in Eau Claire WI, Kato Track and Welding  , Crawler Welding in Mankato MN.
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 12:12am
I've got two good ones. Shipping from San Diego area to MN is the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 12:14am
John Parks at General Gear is an excellent reasonably priced source for a lot of AC parts.
This page was generated in 0.240 seconds.
