HD5 final drive seal
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: HD5 final drive seal
    Posted: 20 May 2017 at 9:12pm
I just put final drive seals in my dozer, put them all together, moved it a few times with the tracks off, finally put the track frames and tracks on and moved it around today and the left one started leaking. Any experience? Should I run it and see if it seals or take it apart and see what is up? They go in easy so I can't imagine what went wrong. Glued them in with the proper glue and had resistance on the seal.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 6:53am
I assume it is the inner seal. I think the steel seal slipped off the drive pins in the spring assembly. I put gear oil between the steel seals during assembly. If I am correct the situation will get worse if you don't fix it now. My best guess   Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 1:43pm
I did oil the steels during assembly. it is the inner seal, naturally I have to remove the track and track frame to get to the sprocket. I figured I better get it now before I go any further in assembly but was hoping for the best. I know they would leak occasionally and then stop, usually due to temperature change. not happy about it that is for sure as I need the dozer. thanks for your reply.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 9:09am
I had the same happen to the input seal on the transmission - problem is now the yoke seems to be stuck on splines and so far have not been able to remove the yoke -
 Need to check one rear sprocket seal also as it started weeping last fall .
Guess after 40 years of owning the machine i need to keep up on things better - still the same rear seals as when i bought the machine - just welded on sprocket rings when I put the new track on .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 9:12am
On a HD5B I had rather than remove the truck frame - I cut the end of the frame that holds the outboard bearing - I made a jig to hold that section in line before torching it off - then when going back together after replacing sprocket, bearings, and seal I installed the jig and welded cut off section back in place .
This page was generated in 0.211 seconds.
