HD-5 Filters, Main clutch |
BFC
Topic: HD-5 Filters, Main clutchPosted: 10 May 2025 at 8:02pm |
Filter for original canister Oil Filter Wix #51010 Fuel Filter Secondary Wix # 33511 Fuel Filter Primary Wix # 33010 Name all WIX I did change main clutch from Rockford Clutch to Auburn Clutch. Operate as should. Have great day!
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42261 |
Posted: 22 May 2025 at 3:54pm |
Updates across the HD5 line were common , from Vickers hydraulic pump to increased length of pin bosses on loader frame mount .
From 5 speed transmission to 4 speed and hi and low reverse gears Early 5G loader frame used a box beam between loader arms , later went to a round tube with upper and lower formed plate which stiffened the full loader frame |
