hd5 fan belt |
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Topic: hd5 fan beltPosted: 28 Aug 2016 at 8:41pm |
does anyone have a part number for the fan belts on a 2-71 Detroit in a hd5? aftermarket part number is ok. thanks.
DavidnTenIll
Bronze Level Access
Posted: 29 Aug 2016 at 8:47pm |
TR 22625 Gates I believe.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42279 |
Posted: 29 Aug 2016 at 9:21pm |
I used a B series belt - think a B58 - but then i have my machine modified with a Alternator for charging battery and a starter motor with solonoid so it's key start .
dadsdozerhd5b
Posted: 05 Sep 2016 at 8:45pm |
THANKS FOR THE REPLIES. COLE, WHAT ALTERNATOR DID YOU USE WITH 2 PULLEY SLOTS?
dadsdozerhd5b
Posted: 05 Sep 2016 at 8:47pm |
SORRY, MEANT COKE.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4875 |
Posted: 06 Sep 2016 at 11:31am |
I have a one wire delco like from a 80's pickup on mine.The shaft fits the double pulley that was on the generator.
Coke-in-MN
Posted: 08 Sep 2016 at 11:53am |
I took the pulley from a 78 GMC 427 truck engine alternator - 2 groove pulley - narrow belt - chucked in lathe and opened up to accept the B belt - bore of pulley fits any 10SI alternator and with small size and deep belt - it charges well.
Cast iron pulley so easy to cut deeper and wider . |
