HD5 Clutch Parts Needed
hodaka View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hodaka Quote  Post ReplyReply Direct Link To This Post Topic: HD5 Clutch Parts Needed
    Posted: 26 May 2019 at 2:28pm
Hello,
I have purchased an Allis Chalmers HD5 bulldozer.  I currently have the engine out and am doing an overhaul.  It has a Rockford clutch in it.  Does anyone know where I can find Rockford clutch parts? My internet searches have not yielded any results. Thanks
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 3:21pm
General Gear & Machine keep good stocks of dry clutch and brake parts. They have a website.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hodaka Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 5:12pm
Checked out their website, all I see offered are parts for Auburn clutches.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 5:47pm
Let me have part number maybe I can help with ROCKFORD cluch  I ben robbed last weeken but could check  what parts am still have.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 2:07pm
I got some parts from MINNPAR for a clutch a few years back . I have a few used parts but probably not what you need .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 3:34pm
Sorry to hear scumbags have helped themselves to your stock Hector
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 5:38pm
I check todays about cluch ROCKFORD and am still havea ring adjusting,1 washer pressure,a ring ,a plate adjusting,a plate back,a sleeve,a plate for the cam,a carrier and maybe some small parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hodaka Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 10:31am
The part numbers I am looking for are 073906- this is the clutch camshaft and possibly a pressure plate part # 078669.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 4:26pm
I have the plate and check tomorrow for the cams and comback
Post Options Post Options   Thanks (0) Thanks(0)   Quote hodaka Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 10:51pm
Thanks everyone for all the help. However I have now found the cylinder head is cracked between the valve seats and injector tube. Looking for a cylinder head or a shop to repair mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 10:51am
I have 3 cams. for the cluch ROCKFORD
