HD5 bigger injectors
serioussam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Topic: HD5 bigger injectors
    Posted: 29 Dec 2015 at 7:50pm
Looking at putting bigger injectors in the 2-71
And would like to know my options thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2015 at 11:18pm
I put 70's in my 6-71 and drove it on the floor.Never had an issue from injectors.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 5:30pm
I ran 70's in my truck inline 6-71...that gave in the vicinity of 250 HP. You should be able to count on about 40 (+) HP per cylinder. 65's would work well too...about 35 HP per cylinder. Your HD 5 likely came with 55's new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 6:13pm
These engines ran the older HV ( high valve) injectors. They originally came with HV6 but you can put in a HV7's. From what i was told the 6's had better power at high speeds and the 7's were better at low end torque. Are HD5's have HV7's in them and have no complaints.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 7:00pm
I have HV 7 in mine - 2nd set since i owned it - last set I had rebuilt and bought through truck company I plowed snow at - cost me $27 each exchange...
probably more now ...
