HD5 axle failure cause
Bergie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bergie Quote  Post ReplyReply Direct Link To This Post Topic: HD5 axle failure cause
    Posted: 24 Jun 2013 at 10:59pm
After removing the axle that brokein front of the nut, I'm wondering why this happens. I did notice that the support arm pin/bushing had about .040 of wear. Would this cause the rail to wonder back and forth enough to cause a problem?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2013 at 8:39am
Movement of the track frame would be like a lever in putting pressure onto the bearing area of axle . As the truck frame is supported in two places both on rear housing and by the link-belt double roller bearing, a heavy side load might cause problem .
 I do have a axle if you need one .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bergie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2013 at 1:08pm
I have an axle and all the parts, but I was wondering if it would be worth replacing that pin/bushing. Do you have one of them to sell? Otherwise I could make one I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2013 at 1:35pm
Sold that along with the truck frame I had extra, don't think I have another one around. Might try shimming the end .
 On the HD5B I had the casting where the inside mount was located broke on the previous owner . He ran the machine until he broke the axle also . Left track would walk out about 3" or more on front .
This page was generated in 0.234 seconds.
