HD5/6 sterring clutch assembly |
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Topic: HD5/6 sterring clutch assemblyPosted: 13 Apr 2014 at 10:26pm |
We are assembling steering clutches on an HD5B. The book calls for "Supremalube or an equivalent" to be used on assembly. I am unfamiliar with this product. Can someone Please educate me?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 14 Apr 2014 at 9:17am |
? Where is this called for to be used ?
Ages Cat
Posted: 14 Apr 2014 at 1:36pm |
i am assuming where the teeth make contact with the drum. it is very vague as to the specifics. The HD6 manual wording is similiar.
Ages Cat
Posted: 14 Apr 2014 at 6:02pm |
Quoting Service manual: "Lubricate hub teeth with Supremalube or its equivelant".
Ages Cat
Posted: 19 Apr 2014 at 8:20am |
I spoke to several people regarding this assembly process and the consensus is use Hi-Temp anti seize compound.
Coke-in-MN
Posted: 19 Apr 2014 at 3:13pm |
this must be on metal plate teeth to the inside drive hub .
I never did lubricate any of these as it seemed on most machines i flushed the clutch housing and plates with diesel by installing plug in case drain and adding 5 gallons of diesel then running machine and operating clutches to flush them and free them of any trash or oil.
