Hd5/2-71 flywheel specs |
dadsdozerhd5b ![]() Orange Level ![]() ![]() Joined: 27 Sep 2009 Location: lansdale pa. Points: 531 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jan 2025 at 6:20pm |
Anyone have the specs for the step between clutch surface and pressure plate mounting? Having the flywheel cut and want to make sure the flywheel is right before I install. Thanks.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41774 |
Whoever is grinding the flywheel should have that spec . Detroit 2-71 is common to most other Detroit flywheels using the lip .
Had mine resurfaced when I went to bi-metal disc to replace fiber clutch disc . Shop knew the specs . |
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
Thanks, disc is hard to find. Wanted to swap also. Shop said they would find it just wanted to check it myself when done.
Standard disc (fiber) is also the same as a IH L190 truck from 50's - Black Diamond Gas engine used with a 5 speed transmission
Edited by Coke-in-MN - 10 Jan 2025 at 10:57pm |
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 967 |
Thank you for that useful tidbit, I took a screenshot and put it in my archives. The International L-190's with which I am familiar had Red Diamond engines.
Thanks for the info. Will check it out. Found some but all have springs in the center, original does not. Thinking I do not want springs. Already enough play in system.
Be sure to replace the pilot bearing in flywheel with sealed bearing and plug the oil wick hole if it has not already been done .
