HD4
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Topic: HD4
    Posted: 27 Nov 2009 at 10:03am
Hey guys, we picked up a HD4 not long ago and have some questions.  On the throttle, should it be an accelerator or a Deaccelerator? Ours is set up as an accelerator on the pedal and no hand throttle but some of the linkage looks like it might be homemade?   Also does anybody have any idea on where to get tracks for these old things at? Ours are pretty worn and it will need a set here sometime. We cant seem to find any place that has them?  Thanks!!
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2009 at 10:44am
Pedals could be had both ways. I prefer decellerator myself. Tracks are expensive. Might try Ivan Sumerix, Lachine MI. He will have most stuff you need. HTH Tracy Martin
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2009 at 2:48pm
MN HD4 loader was de-cillerator and the throttle was on side by fwd / rev lever on left side of machine operators seat.
 I had pins and bushings put in my old tracks as the rail height was still good.
Track and sprockets might be hard , believe H3 sprockets are the same , as are 653, 655 machine parts .
jlhincexcavation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlhincexcavation Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2009 at 6:28pm
Try Heavyquip.com. They are aftermarket parts mainly with tracks, rollers, etc. They can also press pins and bushings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 11:03am
ok thanks guys, we are making the parts to change ours over to a deaccelerator... I will look into some of the places mentioned on the tracks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 2:40pm
I noticed with the HD4 the brakes are hard to get use to also with de-cillerator on right as the left foot is then used for both brakes. Hard to train oneself to use just one foot to turn after you run a HD5, then the FD5 I have has steer clutch and brake on same pedal, de-cillerator on both sides and a single brake pedal in center that will apply both brakes and clutches to stop machine NOW.
 Seems there are not enough hands and feet to go around at times. On HD5G with hand clutch, lever steer and loader valves I have run out of hands many times.
tomwestky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomwestky Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 5:03pm
Been learning to drive my HD4 and I've experienced hand, foot, eye mis-coordination a number of times.  Trying to learn to drive with left foot on steering brakes too.  Don't have the decelerator.  Most of my confusion is coming from the blade control levers. Up and down ...no problem but the other two aren't embedded in the brain yet.
Have pushed up a bunch of ice storm stumps, limbs, etc. and pushed a bunch of dirt around.  I've enjoyed every minute.
Tom Westerfield
Crofton, Ky
randalleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randalleky Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 1:17pm
hey, does anybody know the weight of an allis chalmers d2200 engine complete with starter, fuel pump, manifolds attached ? thanks randal
randalleky
This page was generated in 0.332 seconds.
