HD4
Mike K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Topic: HD4
    Posted: 15 Jul 2023 at 10:54pm
Cylinder swivel ends. Where the pin goes through. All cylinders are have loose ends.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 4:44am
Loose ends are common. Need photos of the affected areas before recommendation for correction.
That's All Folks!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 2:04pm
If you mean pins and bushings on cylinders , they bushing is replaceable and needs to be done before they wear through to the actual cylinder end and wears that area .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 10:24pm
Where would I get the bushings
