HD41- FULL PULL
ACHD25 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACHD25 Quote  Post ReplyReply Direct Link To This Post Topic: HD41- FULL PULL
    Posted: 13 Mar 2015 at 10:02pm
A HD-41 AT CHURNIN DIRT NATIONALS DOES A FULL PULL & BEYOND...VIDEO ON
YOUTUBE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2015 at 5:48am
Need to hook up 2 sleds in tandem...
[TUBE]https://youtu.be/uEGxyp-hGUc[/TUBE]
Edited by DiyDave - 14 Mar 2015 at 6:05am
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2015 at 11:39am
http://youtu.be/uEGxyp-hGUc
OK so why doesnt the video link post ?  At least i cant see a link but did find it .
Neither try to post the above would bring up preview .
My computer or another problem ?
Edited by Coke-in-MN - 14 Mar 2015 at 11:41am
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2015 at 1:42pm
It works Coke.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2015 at 6:09pm
[TUBE]http://youtu.be/uEGxyp-hGUc[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2015 at 7:57pm
with a ripper attached , that was an 80 ton tractor... assume the ripper was 10 tons, that leaves the tractor and blade above at 70 tons. Assuming 80% traction, it could drag 56 TONS thru the trap !.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 7:16am
I think you mistook pounds for tonnage, 80,000# is but 40 tons, rippers sat in around the 10,000# mark not tons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 7:48am
Don, a fully loaded 41B was around 160,000 pounds, or 80 tons. It had a 18-20 yard blade which would be about 50- 60 tons of "push"
