HD4 wont move |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Topic: HD4 wont movePosted: 14 Jan 2010 at 7:01am |
Uncle has an HD4 that works great, except after 10 minutes of running it will stop moving in foward or reverse until it cools back off, then it will move for 10 minutes again. We havent had a chance to look at it yet, but was wondering if anyone ran into this before or has any ideas what too look for
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 14 Jan 2010 at 11:18am |
Sounds like a torque converter problem.
Are the fluid levels up? Does the oil smell burnt?
ivan
Joined: 12 Sep 2009 Location: NE Michigan Points: 319 |
Posted: 14 Jan 2010 at 12:45pm |
i can help 989 379 2721 |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42276 |
Posted: 14 Jan 2010 at 4:13pm |
Clutch pack in the fwd/rev worn or hyd pressure low to hold clutches.
Get info to find hyd pressure for the system. also there is a filter in the system and a screen on intake.
On mine the spring in the fwd/ rev valve broke on one side of valve body and the slide valve would not move into position to allow oil to flow to clutch pack. Replaced the spring and worked fine. Edited by Coke-in-MN - 19 Jan 2010 at 9:13am |
DonDittmar
Posted: 18 Jan 2010 at 7:24am |
Thanks guys. I will let you kow what we find when we tear it down
orangereborn
Posted: 12 May 2010 at 12:14am |
Don...You ever find you problem source? Thanks....Dale
