Hd4 parts needed |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Topic: Hd4 parts neededPosted: 07 Sep 2015 at 4:04pm |
Guys I am looking for the shuttle clutch control valve for an HD4. This is the valve on the left hand fender that you shift for forward neutral and reverse. Got a dozer here I can get good pressure to it but nothing out of it. Yes I have had it apart. It is beyond repair
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 07 Sep 2015 at 5:57pm |
Sumerix Equipt. should be able to help. Might try Blount epuipt. in Hoboken, GA. HTH Tracy
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Posted: 07 Sep 2015 at 7:24pm |
IS IT JUST THE SPRINGS BROKEN OR DAMAGED TO WALLS OF THE VALVE BODY ?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 07 Sep 2015 at 11:12pm |
Beyond repair ? center neutral - and 2 ports hold - should be able to find a valve - say surplus center - aftermarket . Or have yours rebuilt - see if Minnpar has pieces to rebuild .
DonDittmar
Posted: 08 Sep 2015 at 5:03pm |
Thanks for the tip Tracy. I will check them out
