Hd4 Decelerator
Piglet2006 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Piglet2006 Quote  Post ReplyReply Direct Link To This Post Topic: Hd4 Decelerator
    Posted: 11 Dec 2025 at 8:18pm
Well guys I used to. Be registered as Randaleky but could not get logged back in so I am now Piglet2006 so has anyone on here got a decelorator for an Allis Chalmers HD 4 dozer . By the way a lot has happened in my life the past 5 years. I lost my wife to sickness in 2020 and our only child age 44 in 2023 . I remarried after this and have a great life . I have a lot of friends on this site and am glad to be back . God is always in control and does as he pleases always . Missed you all
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 9:20pm
Randal I am working on a batch of five now. One has your name on it. Been really busy this year with all that has went on. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Piglet2006 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2025 at 8:06am
Thanks Tracy , I appreciate it. I thought you might be too busy to make them so I thought I might check around on the forum , I hope all is well with you and Hanna and family .
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 12:01pm
A HD4 without one is a full experience to run  - somehow with brake pedals set close and the fact using just one foot to steer while using other to control throttle - well confusing is the results .
 Seems my HD5G using hands on track clutch levers and L or R foot on brake , then left hand on main clutch - right hand on loader controls but - then also L or R hand on the track clutch - well least the 2-71 throttle stays the same WIDE OPEN as you play with levers and 2 pedals .
 My HD5G / HD5B seems old school when looking at FD Power shift and pedal steer but least - foot pedals are set apart so it's easier - and another center pedal to stop all motion when depressed .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Piglet2006 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 3:23pm
Well, coke I ran a caterpillar D6c four years and became used to accelerators, regardless of what I have to do with the left hand and the right always on the blade . It became second nature I have a harder time with a high throttle and trying to steer. I’d rather have a low throw in tight places I can throttle down and maneuver much better. I guess that’s what you get used to as long as we get the red job done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 8:06pm
I remember needing 3rd leg when decellerating braking and tilting blade. D6C 10K
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 16 minutes ago at 2:11pm
That is where the newer machines come in - ease of operation and almost loss of thinking , and SKILL takes over in doing all the operations without having to think about the next operation .
  It's like the wobble stick control of doing more than one operation when moving your hand - fwd / back and side to side all doing separate functions . Difference between 2 stick or 4 stick backhoe - and then someone comes up with a joystick and puts more controls on it .
 Going to a excavator controls with joystick , along with foot control of motion then swing of full platform - GUESS RUNNING A HD4 was easy when just right foot slowed down engine enough to stall torque converter to bring machine to a stop or crawl
