HD3 Thermostat
AC$$$$ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Topic: HD3 Thermostat
    Posted: 30 Jul 2015 at 9:13am
Does anyone know where I could find a thermostat for my HD3 track loader? I found the part number in my HD3 manual but when I order it by that number it is not correct. The manual shows the thermostat fits inside the top radiator hose, and is held in place with a clamp around the hose. Can anyone help?
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 8:20am
I would think any auto parts store can help you or tractor place. Its probably the same as the tractors that year. I would test it first by putting in a pan of water, heat it up to see if it opens. There should be a number on the thermostat that any parts house can cross reference. norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 8:42am
I have tried all major parts stores and no one has a clue what I am talking about. I ordered one for the same year tractor but it is a conventional type thermostat which will not work. The type of thermostat for the HD3 is installed in the upper radiator hose, and held in place with a hose clamp. I cannot check the thermostat because when I got the loader it had been removed. I looked on Google and I saw a photo that looks just like the one in the manual but I have had zero luck finding it.
Thanks for your help
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 11:58am
You are correct. The thermostat fits inside the hose. Did you go the the MINNPAR site, or give them a call? Kevin @ Illinni can help as well.. His add is at the bottom of the page.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 3:09pm
Call 660-295-4661 There in cairo Missouri. Mc Allister @ SONS TRACK SERVICE/dozer place. there very good about locating parts. norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 3:10pm
I called MINNPAR and gave them the part number but the description was not a in the hose type. I am now being told that the same thermostat is in an 8N Ford. I called and talked to the dealer and the measurements are correct, in fact he said he has sold several for applications other than a Ford. Thanks for your help
brettssac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettssac Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 9:56am
It is the same as a 8n ford thermo and tsc sells those
BX2,IB,WC,D15IG, D15IIDX3,D17DI,IID,IIID,IVD,D19DX3,D21II,HD3,185,AND GOD ONLY KNOWS THE EQUIPMENT
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 10:35am
I picked one up from FORD and it fit perfect, and works just fine.
Thanks for your help.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 4:49pm
Same tstat as a D15 diesel. I got mine from Brenda at Sandy lake
1968 D15D,1962 D19D
This page was generated in 0.180 seconds.
