HD3 question |
kip in cny
Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
Topic: HD3 questionPosted: 11 May 2010 at 5:30pm |
I figured out its not a roller thats making my HD3 only go 1ft forwards and backwards. It sounds like somthing in the final. I was using the other day and it wouldnt move more then a foot eather way. Any one have a idea what happened ?
160 CA 920diesel 5020 HD-3
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 11 May 2010 at 5:36pm |
Hope it isn't the bull gear or ? Also bearings that hold rear axel in case are a weak spot.
On HD4 I had to have both cases machined to install new bearing cups as they ate out from force of tract to case movement.
Kipn
Joined: 12 Sep 2009 Location: Tewksbury, Ma Points: 800 |
Posted: 12 May 2010 at 10:08am |
My outer axle bearing fell apart and the rollers fell into the final drive pan. There is very little room between the pan and bull gear. It picked up a roller and jammed it on the pinion gear. Fortunately I'd say that it chopped up the bearing roller instead of the pinion or bull gear. Both were marked up but not beyond being usable. Loosen up the tracks and see if one of the sprockets rocks as in no bearing left. I did question your track roller need. I just chalked it up as misunderstanding your problem. Get the whole machine off the ground with jacks, you are gonna hafta anyway, pull a steering clutch lever and spin the track with a crow bar. Both sides. If one side moves and the other side doesn't, its in that final drive. If neither side moves, it's in the rear end. Either one, drop the pan or cover and you should see the problem. Keep us informed.
1961 H3
kip in cny
Posted: 12 May 2010 at 10:39am |
I picked the dozer up in the air yesterday. I found the right side track will only only turn a littel Iam going to pull the rear cover in a day or 2. The left side works fine.
Kipn
Posted: 12 May 2010 at 4:57pm |
Probably blew that side bearing. I have the part numbers if you need them. Pull the right final pan. You'll probably see your problems in the pan.
Edited by Kipn - 12 May 2010 at 5:01pm |
1961 H3
kip in cny
Posted: 12 May 2010 at 6:00pm |
next question is how hard is it to fix if thats the problem.
Coke-in-MN
Posted: 12 May 2010 at 7:12pm |
Bearin isn't that big , if the case is worn , you need a good machine shop to cut out old race area and weld in a new cup to hold the race into casting. Steel machinement that is welded in.
