HD3 Gas Engines |
mark/indiana
Joined: 14 Sep 2009 Location: Central Indiana Points: 129 |
Topic: HD3 Gas EnginesPosted: 16 Nov 2009 at 6:38am |
Should these have a fuel pump?? Mine has one that is not hooked up...the fuel is fed just like on the gas tractors?? What industrial applications might have used a fuel pump?? Thanks, Mark
mark/indiana..."My favorite Allis Tractor or Crawler is the one I'm sitting on at the time!!..
Bret (OH)
Joined: 15 Sep 2009 Location: Blanchester, OH Points: 353 |
Posted: 16 Nov 2009 at 7:35am |
Yes the H3 (which is what it would be if it were a gas) used a fuel pump. I would assume that since they could operate on more serious grades than a wheeled tractor the engineers thought a fuel pump was necessary.
Kipn
Joined: 12 Sep 2009 Location: Tewksbury, Ma Points: 800 |
Posted: 16 Nov 2009 at 9:22am |
Mine has a fuel pump. The manual says it's a 3-4 pound pressure pump. If you have a gas dozer it would be an H3. HD3 means it's a diesel. HTH
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 16 Nov 2009 at 4:10pm |
Mine has a fuel pump as well.
Matt(MI)
Joined: 20 Sep 2009 Location: Oakland, MI Points: 8 |
Posted: 16 Nov 2009 at 7:41pm |
Mine has one too. It'll run without it, but make sure to keep your tank at least 1/2 full if you'll be working any serious grades.
Harry up of Mi.
Joined: 13 Sep 2009 Location: Gladstone, MI Points: 73 |
Posted: 19 Nov 2009 at 9:50pm |
I have two H-3s, both have after market electric fuel pumps on them. They work fine. They are wired through the ignition switch.
