HD3 Gas Engines
mark/indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark/indiana Quote  Post ReplyReply Direct Link To This Post Topic: HD3 Gas Engines
    Posted: 16 Nov 2009 at 6:38am
Should these have a fuel pump??  Mine has one that is not hooked up...the fuel is fed just like on the gas tractors??  What industrial applications might have used a fuel pump?? Thanks, Mark
mark/indiana..."My favorite Allis Tractor or Crawler is the one I'm sitting on at the time!!..
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 7:35am
Yes the H3 (which is what it would be if it were a gas) used a fuel pump.  I would assume that since they could operate on more serious grades than a wheeled tractor the engineers thought a fuel pump was necessary.
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 9:22am
Mine has a fuel pump. The manual says it's a 3-4 pound pressure pump. If you have a gas dozer it would be an H3. HD3 means it's a diesel. HTH
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 4:10pm
 Mine has a fuel pump as well.
Matt(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 7:41pm
Mine has one too. It'll run without it, but make sure to keep your tank at least 1/2 full if you'll be working any serious grades.
Harry up of Mi. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 9:50pm
I have two H-3s, both have after market electric fuel pumps on them. They work fine. They are wired through the ignition switch.
