HD21P help
Traveller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Traveller Quote  Post ReplyReply Direct Link To This Post Topic: HD21P help
    Posted: 04 Jul 2024 at 9:37am
I have an HD21P that has been sitting for I don't know how many years.  was moving it to load on trailer and blew a steering/brake hydraulic line(one of two long lines from rear to front filter assembly on left side), replaced line and it worked for a few minutes then i lost both sides steering and brakes. tried bleeding the lines and still nothing.
second question : how long should it take to have transmission oil pressure? seems to take a very long time before pressure comes up and it happens all at once, from 0 to operating pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 12:23pm
Suction screens are probably loaded as of the Surge when the Line burst, will need to pull them ALL down clean and inspect, change filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Traveller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 1:05pm
thank you for the reply. ill check that out as soon as i get back to it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Traveller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 5:53pm
how do i get to the screen?
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 8:51pm
These are all cartridge filters and element screens. Look for your power steering pump and the lines will run right to them.
Need a serial # for the tractor to help further. Most of the cartridge screens are cleanable with time and a solvent tank; filters should be replaced.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Traveller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 9:03am
sn# is 13374
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 4:08pm
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Traveller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 12:14pm
thanks again. the filters didnt look too bad. i replaced the second long line and had steering for about 50 feet again then lost it again.is there a way to bleed the system? also i cant seem to find where to add the fluid. its only at minimum operating range on the dipstick (if its the correct dipstick that im checking) im  missing the most forward dipstick of the 3 next to the seat. the most rearward dipstick seems to be the correct one.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 12:59pm
Try going to"General Gear" a after market seller of steering clutch parts for all crawlers. In the last years they added parts books for sure, but I think other books to help people working on the old stuff. So they may have the operators book you desperately need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Traveller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 7:13pm
thank you. ill check them out
Doughd16b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doughd16b Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2024 at 4:00pm
I think I can help, 252 916 2927
Post Options Post Options   Thanks (0) Thanks(0)   Quote Traveller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2024 at 8:09pm
Thank you i will give you a call tomorrow (friday)
This page was generated in 0.281 seconds.
