HD21 TORQUE CONVERTOR
R.KYLE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Topic: HD21 TORQUE CONVERTOR
    Posted: 22 Aug 2016 at 10:18pm
DOES ANYONE KNOW IF PARTS ARE AVABALE TO REPAIR LEAKING TORQUE CONVERTOR? ALSO WONDERING IF CLUTCHES AND PRESSURE PLATES ARE AVABALE? MACHINE IS 1960 USES DIESEL IN TORQUE.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 12:56am
Sorry, I don't know about parts availability but I wonder if you are right about the TC fluid. Usually they use Dexron automatic transmission fluid, (red like diesel fuel).
Allis Express participant
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 2:42am
Early torque converters did run on diesel fuel. They were made by twin disc corporation; who are still in the same business today. Converter should have a model tag on it. Try a twin disc service agent if the numbers correspond to any info they have.
tits tyres and tracks
they all cost you money
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 3:09am
JohnCo
They did.  Story around here of one being refueled in the dark after a hot day on a chaining job.  Operator used a cig lighter to check the fuel level.  Lost his eyebrows but not the dozer.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 6:53am
Ian, kind of a funny follow up story(OT) that was somewhat like yours. One of the drivers in the same company I was leased to showed up one day with a tremendous suntan. I asked his boss how he got such a tan in the middle of winter. In the real cold parts of winter we used to add some gas to the diesel to thin it out to keep it from jelling. (Not a good idea). Well, this drivers fuel gauge had broken so he decided to see how much fuel he had by the light of his cig. lighter. Forgetting he had been using the gas additive he leaned over to look in the tank and struck his lighter. Instant explosion. And that's the way he got his winter suntan.
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 10:57am
Try John Parks at General Gear... They should have a website and are excellent to deal with for parts ...  Sorry, on road and don't have a phone number handy !!  Good luck...  Diesel Fuel Torque converter is correct, early CAT Torque converter tractors also did this !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 11:08am
Learned something new and it's not even noon!  Thanks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 9:32pm
JohnCO
There is an HD19 in our area that has been hotrodded (now an 8V71 and 6 speed manual), which IIRC originally had a diesel converter, so their use spans from there to somewhere in the HD 21 series.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2016 at 12:38pm
The HD16 used diesel too.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2016 at 12:54pm
The diesel converter started way back in the 40's with the HD14C,  and was used into the early 60's.  Im sure for the right money, yours may be able to be rebuilt or a new one made  from a converter producer.
Edited by CAL(KS) - 24 Aug 2016 at 12:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2016 at 8:51pm
CAL I THINK YOUR FATHERS HD15 IS THE COOLEST TRACTOR ON YOU TUBE. I HAVE TO SEE IT AT LEAST ONCE A WEEK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 5:25am
This the one?
[TUBE]http://youtu.be/TNRs4Qwje7Y[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 9:06am
yes, my brother has some other videos of it on his youtube also.  It has been a very reliable machine. It was originally from a county landfill where it pulled a cable scraper and wasn't abused. We bought it from the second owner who had installed a blade on it. That blade in the video is from our 16D parts machine as the one on it from previous owner was sourced from a quarry tractor and just plum worn out.
Edited by CAL(KS) - 25 Aug 2016 at 9:09am
This page was generated in 0.143 seconds.
