HD16AC oil leak
sdtplus4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdtplus4 Quote  Post ReplyReply Direct Link To This Post Topic: HD16AC oil leak
    Posted: 27 Oct 2017 at 10:00am
Im losing transmission fluid out the track pivot pin cap, according to my parts breakdown there is a wick that goes from pin into transmission case. How hard is this to replace? Do I have to remove the track assembly or can I just support the dozer and  pull the caps and pin??? Im running 15w40 in the transmission
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 11:07am
its been awhile since ive had mine off but IIRC  the caps come off and the pin has drop down to be free of the dowel.  The wick is located inside the dowel that goes between the housing and the pin.  When I had mine off I had to move the whole truck frame foreward to remove the sprocket so I also had the axle shaft loose from the frame.  I don't know if the pin will drop out with the axle shaft attached or not.  Likely your pins are worn and/or the seals on either side are bad.
Edited by CAL(KS) - 27 Oct 2017 at 11:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdtplus4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 3:05pm
I will check out the seals thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdtplus4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 7:07pm
I pulled my cap and there was nothing in the dowel pin , I could run a wire into transmission case, so I put in a piece of felt and hope it holds.
This page was generated in 0.182 seconds.
