HD16A
conoco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote conoco Quote  Post ReplyReply Direct Link To This Post Topic: HD16A
    Posted: 12 Aug 2025 at 6:43pm
Recently got my dads hd16a running from sitting 20 years. Went thru coolant system, replaced pipes, hoses, cleaned out complete coolant system i even had radiator core made. I replaced all filters and engine oil. The dozer starts up and idles like a champ. I am looking for thermostats for it and cant find any (part #74378269). Does anyone carry parts for an HD16A?
Adrian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adrian Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 8:04pm
If you have the thermostat and can find a number on it use that. If you can also find a manufacture that helps more, that's how I found one for my HD6.
Post Options Post Options   Thanks (0) Thanks(0)   Quote conoco Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 8:30pm
the dozer takes 2 thermostats. It only had one installed. The thermostat says it was manufactured  by Vernatherm Valve. It has some numbers on it but cant find anything in the web.
ecosse23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecosse23 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2025 at 1:34pm
Don't know whether this is perhaps what you're looking for -
https://www.ebay.com/itm/276813360734
The seller describes it as "Thermostat 4cyl. diesel Allis Chalmers HD-6ED pn#74378269". So it appears like the right part number, but perhaps for the wrong crawler tractor?
