Hd16
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Topic: Hd16
    Posted: 07 Apr 2022 at 10:13pm
Guys I have a chance to buy a very early HD 16. Guy said it runs good but the tranny is out. Tracks and undercarriage are decent. He told me transmission parts are no problem as it has a truck transmission in it, possibility a Mack tranny. I've never heard of that. Does any one know 1 way or another? Thanks Guys.
Edited by 200Tom1 - 07 Apr 2022 at 10:15pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 12:34pm
I never heard that one before. Unless it is a I did it cause I wanted one deal, I would not believe it.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 3:39pm
its a 3 speed transmission with a high-low in each gear and 3 reverse speeds.  nothing like a truck except its a manual.  rear of trans has a flange that bolts to rear housing and locates pinion to bevel gear.  pinion stays in transmission when removed.  lost of those transmissions around for parts and easy to work on.  if it runs and has good uc, it would be worth getting.  could be as simple as a bearing.
Edited by CAL(KS) - 08 Apr 2022 at 3:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2022 at 12:56am
Thanks guys. I looked at it today. Needs sprockets and bushings turned, batterys, and quite a few more things. Gonna pass on it.
