HD16
dozermand6b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dozermand6b Quote  Post ReplyReply Direct Link To This Post Topic: HD16
    Posted: 14 Jan 2015 at 8:43pm
Anybody know how the steering system on a HD16 works? the screen canister is 2' above bevel gear/steering reservoir. is there another pump that pumps fluid to screen canister?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 5:13am
what year and type are we talking?  HD16A, AC, D, DC, DP, 16B?  screen canister, do you mean filter?
the early models didnt have filters for the the power assist steering, later  they were mounted on the pressure side near the engine.  will be one for each side.  if you have 1 filter it may be for later model with transmission filter and pump which is located above the trans near the steering control box.
if you are on a DP or 16b i am not familiar with them.
minnpar has parts manuals online
Edited by CAL(KS) - 15 Jan 2015 at 5:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 7:24am
if it works similar to my 7G the main pump at the converter or off the engine for the trans one section scavenges off the trans and sends that oil back into the screen filter case area the other section feeds the trans.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2015 at 7:13am
You should have a oil pump in front cover
