HD16 starter removal
HD16man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD16man Quote  Post ReplyReply Direct Link To This Post Topic: HD16 starter removal
    Posted: 22 Feb 2011 at 5:39pm
I have a AC HD16 dozer which has a bad starter and I'm not real sure about how to remove it the fastest easiest way. I would appreciate any suggestions.
hd16b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hd16b Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 10:33pm
On my 16b it is just a simple unbolt and remove.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD16man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:06pm
The problem I am facing is that there is a pump attached directly above the starter, I am not sure what the pumps function is and if I could cause damage or more work by removing it to access the starter. I don't see how I can possibly remove the starter without first removing the pump or at least it's hoses which presents another issue of them being unflexible for ease of moving them for better access to the starter. I need advise on best procedure to remove  the starter.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 4:34am
they either come out the top or bottom. if the top is too congested, remove the belly pan and drop it out the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD16man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 9:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD16man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 9:34am
It looks more congested through the bottom
This page was generated in 0.088 seconds.
