HD16 Exhaust manifold
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 5:47pm
Would be similar to the old Detroit style mufflers. Horizontal with multiple inlets and one BIG outlet.
rickv57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2017 at 7:38am
Morton have you found you a manifold yet I am going to look at a couple of Parts 16 Sunday will check the manifolds for you
Morten.have View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 9:13am
I’m still really bad need a manifold!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 9:17am
I have found a manifold but would have to buy the whole tractor to get it 1500, if nobody purchases this this machine I may be able to get it later as it will probably be scrapped
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 9:51am
Morton i have this one off my parts machine. The muffler is rusted nearly gone. Seems to me one flange had been welded near a bolt hole but cant see in the picture, but better than yours by far. I can get more pics if your still interested, iv decided that it will do you more good than me so why not help you out. You can pm me to discuss if you wish.
Edited by CAL(KS) - 15 Dec 2017 at 9:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 10:00am
what is the scoop on this machine rick?  where is it?  hydraulic or cable?  lanova or direct?  issues?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 10:05am
Machine is a early model with the Buddha it is a hundred percent complete motor probably stuck, has a cable blade, it is a DC model with a torque, next time I'm up there I will get some pictures, may end up bringing it it home myself as I believe it could probably be a runner with some work definitely a lot of parts, I just have a lot going and several machines already on my agenda
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 10:17am
We feel your pain Rick. Gotta be tough maintaining and keeping track of 20+ machines. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 10:19am
Jerry I lost count I think I'm about 30 now
Don't know if that's machines or IQ LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 10:29am
rick my parts machine is a 16D with buda motor.  strange to have early motor in later long track machine, but I guess you use what works when something breaks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 12:59pm
I travel the country quite a bit for my work. This coming year when I am in your state, we will talk about letting in to see the collection. I would love that Rick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 3:36pm
Hello Cal
Have you ever taken this type of manifold apart ? curious how hard to get the 3 sections separated from the pair of rings on each one. Are they designed to pull apart or are they like a spring clip that you have to work out of the joint?
Thank you
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 6:41pm
Those joints are a "slip fit". To assemble you squeeze them together and slid one manifold section into the other. to take apart you just pull the sections apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:01pm
Old NH Cummins manifolds were as that. Rings did not wear, just a seal for the slip joint as parts heated up and moved around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:10pm
Originally posted by jerbob jerbob wrote:
Hello Cal
Thank you
I have not.  Hope i never have a reason to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2017 at 6:21am
You are an honest man Cal.
Thank you
This page was generated in 0.120 seconds.
