HD14 serial number location?
colesdaddy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colesdaddy Quote  Post ReplyReply Direct Link To This Post Topic: HD14 serial number location?
    Posted: 14 Apr 2016 at 12:22am
Hello all, we're getting ready to sell and I need help locating the serial number on a HD14.  I can't find it even though tractordata says it's "behind transmission case, right side."  Anyone have a better description?  Thank you in advance.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:39am
Upper right hand corner as you face the rear of the tractor. They can be coverd up if the tractor has a winch.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote colesdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:55am
Well then that could explain it.  It does have a large ex-military winch.  Is the serial number on a plate or stamped?  Thank you again for the help.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 9:23am
this is a HD19 but It will STAMPED where the circle is
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 10:19am
HD14 had the same rear end as the L had and they were stamped on top of a horizontal surface down on the right side of rear case. They were not a big hunk of steel squared off like other crawlers were, they had the transmission behind the ring and pinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 10:28am
oops.  thank jc.  I just assumed the 14 was similiar to the 10 and 7
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 1:06pm
an its new version, the HD15...an the bigger version of the 15, the 19..   LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote colesdaddy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 9:38am
Thanks guys.  There was a little dust on it but I found it.  According to tractordata, it was made in '44.
