HD11-EP trouble with hydraulics
MJ2018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2018 Quote  Post ReplyReply Direct Link To This Post Topic: HD11-EP trouble with hydraulics
    Posted: 26 Sep 2018 at 10:32am
Hello my father has a hd 11ep  s/n 13858 that we are having a problem with the blade being very very slow to raise. The line pressure is in the red if your at idle and sets on the line between the red and green at WOT. I have never worked on a dozer before and seeing if you all could point me in the right direction or where to even start.  Possible pump or relief vavle or what not. Thanks In advance.
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 10:56am
howdy neighbor
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2018 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 12:43pm
Hello thereBeer
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 4:11pm
Did you check your oil level and oil filter hydrolic
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2018 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 11:54am
I replaced the filter already and yes all the fluids are at operating ranges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 3:00pm
There are parts diagrams at Minnpar on these, there were a number of variations as to blade cylinders where a few had rapid drop mechanisms. If you could post photos or look at the diagrams perhaps could locate the whereabouts of the issue.
This page was generated in 0.371 seconds.
