HD11E issue
jchance View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Topic: HD11E issue
    Posted: 09 Mar 2014 at 11:37pm
hi,
i have just had an issue with my HD11E serial number 8321.
the engine works fine, however when engaging the clutch handle the dozer will not move forward or reverse.
steering left or right will not work either.
anyone have any ideas what the issue could be ?
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 2:40am
hi/lo levers probably in neutral
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 2:53am
i thought this as well i think it is engaged though
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 12:27pm
Does the transmission pressure gauge show pressure?  If hi-lo is engaged, transmission pressure should show with clutch engaged.  If hi-lo is in neutral, you will have no trans pressure.
I don't have a manual for that tractor anymore, but fill points from memory are:
Engine oil- spring loaded cap at LH rear of engine
Hydraulic oil- square drive plug in front of radiator grille
Trans oil- cap under seat with dipstick
Bevel gear- cap under seat with dipstick
Clutch- dipstick at right rear corner of engine (reservoir is under oil pan)
Steering- plug on reservoir behind engine- fill to plug level
Final drives- square drive (1/2") plugs
Radiator- self explanatory
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 10:13am
You say engaging the clutch so I assume  a manual transmission?Adjust the clutch.
Ray
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 10:20am
yeah i had to adjust the clutch 4 turns
does anyone know where to buy a new clutch ?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 4:01pm
You should have a wet master cluch and make sure the oil tank level is oké
This page was generated in 0.346 seconds.
