HD11E Dozer Questions |
| Author | ||||
bulletpruf
Joined: 27 Oct 2025 Location: San Antonio, Te Points: 21 |
Topic: HD11E Dozer QuestionsPosted: 27 Oct 2025 at 8:27pm |
So, I'm interested in an early 1970's AC HD 11E dozer for use on a ranch. More than anything else, I'm curious about parts availability. Anyone know if you can still get most parts new for these? Undercarriage and such? It's about the right size for me, but if it's going to be looking for a needle in a haystack every time it needs something I probably need to look elsewhere.
Thanks Scott
Please check out my YouTube channel at: https://www.youtube.com/@THEBULLETPROOFGARAGE
| Sponsored Links | ||||
Les Kerf
Thanks(1)
Posted: 28 Oct 2025 at 12:11pm |
What I know about an HD11 would fit on the head of a pin, but I am getting to be quite familiar with an HD5G, and what I have gleaned from this site is that parts for virtually ALL of the Allis-Chalmers crawlers are scarce and getting even more scarce. Undercarriage parts are no longer manufactured so the only stuff available is from the used market, and engine parts are reputed to be extremely hard to find. Best wishes in your endeavors
bulletpruf
Posted: 28 Oct 2025 at 4:21pm |
Here are a few pics. ![]() Here are a few pics.![]() Edited by bulletpruf - 28 Oct 2025 at 4:22pm |
Les Kerf
Thanks(1)
Posted: 28 Oct 2025 at 8:37pm |
I love it! Better take a real close look at those tracks
The near side is almighty loose ![]() |
bulletpruf
Posted: 28 Oct 2025 at 8:44pm |
Yeah, the undercarriage doesn't look great to me, either. I'll definitely spend some time checking it out when I go see the machine this weekend. Scott
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34573 |
Thanks(1)
Posted: 29 Oct 2025 at 1:00am |
These are dry pin rails, they will wear to a point internally where will snake terribly and roll off readily. Can appear in great shape externally and be junk. 7.0” pitch where no other manufacturer save IHC used. No one stocks parts for these US, getting from overseas is beyond expensive if can even locate there.
These are 40-50 year old machines, in most respects there are no new and dribbling to nothing used parts remaining to keep them viable. |
gemdozer
Thanks(1)
Posted: 29 Oct 2025 at 7:54am |
I dismantled 2 HD11 E some time and am still have some used part but no more track
bulletpruf
Posted: 29 Oct 2025 at 3:08pm |
It looks like there's a fix that involves converting to Cat D5 undercarriage, but not sure if the parts are available to convert, and you have the expense of sourcing all the D5 bits.
bulletpruf
Posted: 02 Nov 2025 at 12:18pm |
Ok, now for some details on the attempted rescue. Picked up my buddy Will at 7:30 am and we headed to Victoria, TX. It's a 2.5 hour drive. Arrived and noticed that we didn't need a chainsaw and a weedeater to be able to get to the dozer; they had cleaned up the area around the machine several weeks ago. Too bad they didn't kill all of the wasps; we must have killed about 50 and went through 3 cans of wasp spray, which is a new record for me.
Anyway, after taking a look at the dozer, it didn't take long to see that this was more of a parts machine than anything else. It's complete, but the undercarriage is in pretty bad shape -- the sprocket teeth have a knife edge and most of the teeth are chipped, too. The track chain didn't look great, although the pins and bushings didn't look to be in terrible shape. The worst part was the track adjusting yokes that move the idler gear - the rods were severely pitted, to the point where they had to substantially weaker than they should be. Most of the control levers were seized up. I managed to get the steering clutch levers freed, the transmission (6 speed manual) shifted ok, and the main clutch worked, but lever to control the blade never freed up, the high-low shifter appears to be stuck, the winch controls are seized up, and I had to undo the throttle linkage because it was seized. Engine was low on oil (barely reading on the dipstick) and I couldn't see any coolant at all in the radiator. Hydraulic cylinder rods for the blade were gouged and rusted, too. Batteries were dated 2001, so I'm thinking the machine has been sitting for about 20 years. Electrical problems started with the batteries and battery cables. We charged the two 12V batteries in the dozer (they were dated 2001 and hooked up for 24V) and they would each read about 12.5 volts after charging, but we only got about 3 - 4 volts at the starter so we had some battery cable/connection issues. The push button starter wasn't working either, so I hooked the 24V jump pack positive clamp to the lug on the starter solenoid where the hot cable came in from the battery, and grounded the jump pack negative clamp to the starter ground. Then I used a screwdriver to jump to the other large lug on the solenoid and just got the whirrrrr noise from a starter that was spinning but not engaging. The starter solenoid is on top of the starter and reasonably easy to get to. I tried to disassemble on-site but unable to remove the solenoid from the starter because there was a nut holding the starter solenoid actuating rod (not sure if this is the "official" term) in place and the actuating rod spun when you turned the nut. The starter solenoid actuating rod has to pull in, towards the front of the starter, in order to push the starter pinion to the rear to engage the flywheel. The actuating rod was spring loaded and I was able to push the actuating rod in, towards the front of the starter, with a pry bar. When I did that, the starter pinion moved to the rear and into the flywheel teeth. However, we were able to watch the starter solenoid actuating rod when I jumped the two starter solenoid lugs with a screwdriver and the actuating rod didn't move in or out. If I had been able to get the starter solenoid off, I think there's a decent chance that I could have disassembled it and at least figured out why it wasn't cooperating. There was an inspection cover not far from the starter that I was able to remove to view the flywheel. The teeth on the flywheel weren't perfect, but they weren't chewed up, so the issue wasn't a bad spot on the flywheel, at least not that I could see. I turned the engine over using the pry bar on the flywheel, so I was able to actuate the starter on different spots of the flywheel with no change. Debating on whether or not I want to go out there with a new starter, to the tune of $450. I won't end up buying it, but if I get a few videos out of getting it running again, I'll make the $ back eventually off YouTube. |
ecosse23
Thanks(1)
Posted: 03 Nov 2025 at 8:07am |
Thanks for the update. Sounds like you might have to soak the controls in WD-40, leave the machine for a few days, then come back and see if they've freed up a bit. Plus figure out a way to remove the captive nut from the starter solenoid, if that's what the issue is. Incidentally, your images aren't showing for me.
bulletpruf
Thanks(1)
Posted: 03 Nov 2025 at 8:14am |
Yeah, I'm using an image hosting site because my pics are too large to attach. I'll see if I can try a work around. I plan to head back on Friday with a new starter, but I don't think I'll need it. I was jumping the starter off the two large lugs; the S terminal was hidden under a battery cable. By bypassing the solenoid, I wasn't actuating the rod that pushes the pinion into the flywheel gear. Figured that out after I got home. Thanks
bulletpruf
Posted: 05 Nov 2025 at 6:55pm |
Dropped $700 at Napa today - remanufactured 24v 40MT starter, a 24v solenoid for a 40MT starter, two fuel filters, and a gallon of Rotella.
I think the starter and solenoid on the dozer are both good, but the dozer is 2.5 hours away, so I'm bringing them just in case. Speaking of the starter, on another thread, someone mentioned that the 40MT starter, which was original equipment on the dozer, was apparently superseded by the 42MT and then the 42MT was replaced by the 39MT. I think the 39MT would be the best option (lighter and spins faster), but I'm not 100% positive that it's a direct fit, so I'm going with the 40MT. The original fuel filters on the dozer are really rough looking, so if I get the engine to spin over, I'll remove them and replace them with new filters filled with fresh diesel (spiked with 2 stroke oil). The oil was barely reading on the dipstick, so I'll add a gallon. If I don't use the new solenoid and starter, I'll return them to Napa on Monday. Edited by bulletpruf - 05 Nov 2025 at 6:57pm |
ecosse23
Thanks(1)
Posted: 06 Nov 2025 at 4:38am |
Good luck with getting the HD-11 going. Fingers crossed a gallon of Rotella takes the level up to the top mark; I guess the crankcase holds 4 or 5 gallons of oil in total? By the way, I use https://imgbb.com/ for hosting - now that Photobucket, Flickr and Imgur each have issues that can make linking to forums tricky. Hope that helps.
bulletpruf
Posted: 10 Nov 2025 at 9:04pm |
Day 2 is done, and she's still not a runner.
I tried jumping the starter solenoid again but on the S terminal this time, using jumper cables to connect two Group 31 12V batteries wired up for 24V. Got the solenoid to actuate, but starter wouldn't turn the engine over. Cleaned up all the contacts and grounds and still no luck, so I fabbed up several cables with new 2/0 battery cable, good lugs, etc (brought cable, lugs, and crimper just in case). Connected everything again, and then I got the starter to spin, but not very fast and it ran down the batteries in very short order. While I was waiting for the batteries to charge up, I added some grease to the track adjusters and as expected, both sides have blown seals. Given the extreme amount of slack in the tracks on both sides, I think that rules out being able to operate the dozer unless you just want to drive a few feet forward or back. Also removed the fuel filters and replaced them with new filters, topped off with fresh diesel. The diesel tank was bone dry, so I added 5 gallons and then drained it a bit to get the worst of the crud out. Got the batteries charged and tried again but still running the batteries down very quickly, even when I added the 24V jump pack. Thinking it through after I left, I believe the clutch is stuck to the flywheel and/or the winch is engaged. If/when I go back, I'll pull the inspection cover off the bellhousing and see if I can tell if the clutch is stuck. Winch controls are frozen in place, but I should also be able to disengage at the winch itself. Might take cutting the cables and some minor disassembly. Anyway, I'd like to hear the old girl fire up, but it's 2.5 hours each way and I've made the trip twice already. We'll see. |
Les Kerf
Thanks(1)
Posted: 11 Nov 2025 at 1:36pm |
First, I admire your determination and enthusiasm ![]()
Just to clarify, is this still using the original starter rather than the new one?
One area where I have encountered trouble on these older machines is the ground path circuit; not just the cables/connections, but the actual machine frame itself. You need a decent voltmeter to test the voltage drop through the ground circuit while cranking; place one voltmeter lead directly on the battery's ground terminal (not the cable terminal, but the battery post itself) and place the other test probe directly on the starter ground point (you may need a helper and fairly long test leads). Observe the voltmeter while cranking; in a perfect world there would be Zero voltage loss, but in reality there will always be some measurable drop. It needs to be less than One Volt, preferably somewhat less than a 0.5 Volt. You can test sections of the circuit to narrow it down if desired. On my Son-in-law's 1950 HD5G we had to run a ground cable all the way from the battery to the starter due to excessive voltage drop through the aged chassis. Best wishes on your project! |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1002 |
Thanks(1)
Posted: 11 Nov 2025 at 4:16pm |
I presume that dozer might have a PSB injection pump?
If so, I don't see a warning about making sure the pump is free before turning the engine.
Given the unobtanium parts situation |
bulletpruf
Posted: 11 Nov 2025 at 4:39pm |
Yes, I was using the original starter. I returned the other starter to Napa and got my $500 back. I was worried about the grounds, too. For the ground from the starter to the frame, it's a metal braided wire, and I was able to clean the connection at the starter, but I couldn't get to the connection on the frame. I did wire in a new ground from the battery negative to the frame using new 2/0 cable, new terminal, and clean metal at the connection. If/when I go back, I could do the same for the starter ground. Thanks |
bulletpruf
Posted: 11 Nov 2025 at 4:41pm |
I believe it is a Roosa Master pump. |
Les Kerf
Thanks(1)
Posted: 11 Nov 2025 at 7:11pm |
My main point is that the frame itself 'may' no longer be a good conductor, a voltage drop test will tell the true tale. You can also do a voltage drop test on the hot side. If those test good then you have either a bad starter, a bad battery, or excessive load (drag) in the engine. |
bulletpruf
Posted: 18 hours 34 minutes ago at 8:23pm |
Video is up in case anyone is interested.
