Hd11e decel pedal
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Topic: Hd11e decel pedal
    Posted: 01 Jan 2013 at 3:12pm
Did any hd11e ever come with a decelerator pedal? Mine still has a hand clutch and adding a decel pedal would shure make it a little easier to operate.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2013 at 7:02am
im sure it was as an option.  Even on my gear drive '59 HD16 it was available, and and 11E is newer correct?    the problem is locating one... i have looked for one for my 16 and people just chuckle when i ask....  im am thinking about building one from linkages off my parts dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2013 at 7:06am
Yeah mine is a 64. I also thought about building one also, but it would be a lot easier to find most of it on another machine with it and rob it off.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2013 at 10:38pm
HD11EP series 1 (American Bosch pump) is the tractor you need to plunder one from. You can just ignore the linkage for the ground speed govenor throttle control, and use only the pedal control. Very good move to install decelerator on any gear shift crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2013 at 6:28am
Anyone out there parting out an hd11ep?
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2013 at 12:49pm
Try Crane and Tractor, in Ohio- parting out dozens of HD11Es.  1 800 322 7311, talk to Jerry.
This page was generated in 0.633 seconds.
