HD11E blade cutting edge
Gargoyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Topic: HD11E blade cutting edge
    Posted: 02 Dec 2013 at 6:28pm
I need a new cutting edge, or at least the corners for my HD11E straight blade.
Any suggestions?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2013 at 10:09am
dozer cutting edges and end bits - enter into google or your search engine - most construction suppliers of other machines can order also.
Edited by Coke-in-MN - 03 Dec 2013 at 10:09am
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2013 at 11:13am
I've bought corner bits for HD11 from both Minnpar and local Case Construction dealer in past year- similar pricing, identical product- bits from ESCO.  About $150 per corner for 1", $200 for heavy bits.  I can get you part numbers if you need 'em.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2014 at 11:00pm
Sure. If you have the part numbers that would save me time hunting them down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2014 at 8:35am
70691684- straight bits
70694289- LH (for angle dozer, also fits straight dozer)
70694290- RH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2014 at 8:31am
This is what the angle bits look like.  Some guys put them on the straight dozer for rooting- some even put longer ones on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2014 at 12:54pm
Nice pile of 'Spares' you have there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2014 at 5:48pm
I'm collecting for my next project...Big smile  Keeping my eye out for a good 11-B with bad undercarriage so I can use my pile.
Edited by Lazyts - 05 Mar 2014 at 5:58pm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2014 at 9:08pm
how hard you gonna use it?  you could do this.  5 lbs rod each side and some cutting edge
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2014 at 1:12pm
Lazyts..
Did you see this 11-B?
http://springfield.craigslist.org/hvo/4274747611.html
I checked this one out 2x in person..
The motor was froze up when rain came down the exhaust. Owner says it's free now. ??
Many of the rollers are in very good shape. The left rails are worn badly. The sprockets are pretty worn.  Many pads are loose
This page was generated in 0.123 seconds.
