HD11B track condition
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Topic: HD11B track condition
    Posted: 06 Jul 2017 at 10:37am
I noticed this HD11B for sale. What do you think of track condition? I got it wrong last time I asked but,.... in this picture the tensioner for  the tracks looks way out , as far as it can go.
Edited by Ferdinand - 06 Jul 2017 at 10:38am
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:17am
imo hard to tell from the picture, its too far away.  its got the long track so it looks way out there but may not be.  really need to base it off of where it sits on the truck frame which you cant see from here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:38am
Thanks for the reply. I'd like to buy that dozer. It has been off and on for sale for 2 years now. He won't answer his ads. The ad says it will run if jump started.
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 3:12pm
It has the longer 8 bottom roller trucks, need to measure the rails for wear on pins/bushings measure across five pins, any five pins same edge to same edge and divide by four, if greater than 7.125 they are pretty well at Zero left. There are other measurements, sprocket wear, wear on the running surface of rails, wear on idlers but all together mean little if the rails are already worn thin.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 3:38pm
That track is to tight looking from the picture.But there are reasons that would make it ok,if it was driven back wards to where it sits slack would be on the bottom. A inch to 1 1/2 inches is normal amount of sag in a track between support.
Running them tight may help keep them from coming off,but also increases the ware.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 12:28am
Here is a link to a page on this forum with the track dimensions for measuring the 5 pins like mentioned above
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 8:03am
One option, I missed the 953 rails, another got them as I could not afford the price on that previous page. The cat 6.906 rails have a smaller diameter bushing and with sprocket wear along with used chain wear may fit well enough to an older machine yet will have to adjust the number of segments to fit your tractor. Rollers are another concern though as Cat rollers will not directly bolt up to a AC machine, trucks have to be dismantled and re-drilled and ground out to use them. This size rail is common to a great deal of Cats but shoes could be a problem as to width, may have to have them cut to fit against a Allis tractor.
Edited by DMiller - 07 Jul 2017 at 8:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 8:40am
Thanks for the info. I'd like to buy this machine. It's been advertised on CL off and on for about 2 years. Every 6 months or so he relists and drops the price about $500.00. Never answers the ad.
Mathew 7:14
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 3:09pm
Maybe a case of the wife asking when he's gonna get rid of that old pile of crap.  "I've got an ad on CL!"
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 10:18am
I have run into those!!
This page was generated in 0.299 seconds.
