hd11-b date???
Message Reverse Sort Order
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Topic: hd11-b date???
    Posted: 02 Nov 2017 at 9:17pm
The adventure begins !
Check back in with progress reports and pictures if you get the time.  Lots of knowledgeable people here to help with your questions, too. Smile
ooops, I say that and one your questions got lost in the thread.
Is it fairly easy to find outer seal kits for the final drives?
I don't know but, there is a resource section on this website. But, you've probably already found that.
Edited by Ferdinand - 02 Nov 2017 at 9:21pm
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14
honeycuttcars View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 3:57pm
I bought it the first day we looked at it and, then bought the starter, and battery cables. I had to wait until they arrived, then install them, and pray that it would start, run, and move, so it could be at least loaded, and unloaded. Then I got it hauled home, the following Saturday. Over all the process took two weeks. During the loading, a 3/4" hydraulic line ruptured and dropped the blade. Thanks to a fantastic driver, He was able to use a chain, and binder to get the blade up enough to load it. We brought it off the trailer the same way.
I live two hours west of Concord.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 2:52pm
I hear ya'.
More nosy questions:
Did you have it shipped the same day you made the deal?
Did have to come back later to work on it to get it loaded?
Whereabouts in western NC are you located? Wife and I vacation in Spruce Pine every summer.
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 1:04pm
The folks in that topic sure expressed how I felt during the purchase of this dozer. I was really scared (after I bought it) that the engine would rattle like a worse than my knees when it was first started. They were correct, the seller was hard to contact, but He was truthful about the sale so far. Sometimes you have to take a chance, and hope it works out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 11:45am
http://www.allischalmers.com/forum/allis-chalmers-hd-11-b-concord_topic141286_post1170300.html?KW=allis+chalmers+concord#1170300
That's one thread about it. Also, you can do an Advanced Search: track condition  and posted by Ferdinand. That thread has a picture of your dozer.
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 9:57am
I would like to read that thread about it. How would I find it? A local logging co. hauled it for me, with no trouble other than a ruptured hydraulic hose, but I am sure it was an original hose. The oil pressure runs perfect, and no major leaks. I have pulled the old non functional generator off and installed a GM style 24vdc, one wire alt, to recharge the battery's. Plans may be in order to install a A/C system to cool the cab. The brake bands work flawless. I will need to re-solder a new neck in the radiator. The one that is on the top tank is bend pretty bad, but it had green antifreeze in it. A lot of what I am finding is issues that have been let go for a long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 9:03am
Good to hear that. It's an old machine, certainly gonna need some TLC. But sounds like you did o.k.  I think he was asking $2800.00, this time, which isn't a bad starting place for a running machine.. There is a thread about that CL ad on this forum.
who did you get to ship it?
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 5:25am
Your pretty close to the story. We had to replace the starter and battery cables before I could hear it run. I bought it with the hope that I was not buying a "pig-in-a-poke". We installed the new parts and it started up after about 5sec's on the starter. Hydraulics worked, all gears good, steering needs some work, and there are some leaks, as well as needing general maintenance. Overall the UC is about 75-80%. I am real happy with it so far, it is a big step up from my old T-340. P
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 9:39pm
The guy you purchased it from has  or had a TD14. He lives in Burlington, NC. I'd really like to hear your story about the sales transaction, was it only a stuck starter like the ad said?  Really curious. He listed the HD about 6 months ago for $1500. I tried to buy it. The guy never answered the ad.
Edited by Ferdinand - 01 Nov 2017 at 9:42pm
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 9:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 9:35pm
Thanks for the replys.. This unit was purchased in concord Nc, and from the grandson of the owner, who had passed away. I was told it had been on the property for over 30 years. There are a few things that time has taken its toll on, that need repair, but she runs strong. It is a non turbo six speed. Is it fairly easy to find outer seal kits for the final drives?
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 9:25pm
B in the serial number after 10, 000 also denotes dry steering clutches, and 7 roller track frame, with pre- 10,000 style track chains I think... and no turbo
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 1:06pm
The B in the model name means its full width track gauge and built for industrial rather than agricultral use. Not to be confused with the series B tractors.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 1:24pm
will be 64.  AC used letter serial numbers after about 1969/70 .   If it was  a  HD11 series B powershift it would be stamped 25L 16257.  My HD11ep is 46Y 14812.  And HD6ep is 88Y24869. Other late HD6s were 40M and 70C.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 4:51am
if the 0 in the 10257, is a 6, then, its a 1971.  If it really is a 0, then it's a 1964, and not a B series...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 9:38pm
Did you by chance purchase that dozer from a man named Russell, near Mt. Pleasant, NC?
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 8:48pm
Hi, I am new here and would like to ask if someone could give me an idea of when my dozer was built. The serial number on the back right side reads...HD11 B 10257. I was told it was a 1964 but would like to confirm that for ordering parts. It has the AC 10000 engine, and hydraulic assist steering. This one is a little different. It has a full cab with no a/c or heat. Any help would be greatly appreciated. Thanks.
