hd11 used transmission parts
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Topic: hd11 used transmission parts
    Posted: 16 May 2022 at 12:40pm
Am still have more HD11 transmissions used parts
10 collars 069244-2 collars 868660-3 collars 069243-1 shaft pinion 077610-2 top shaft 621678-2 intermediare shaft 069252-2 top shaft 095960,1 top shaft 098998 -2 shaft pinion 620753-1 shaft pinion 659391-1 input shaft 623975-
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 7:19am
You wouldn't have a kit or gaskets/seals to rebuild a speed control valve would you?
Little better view or the internals to the shifting valve:
I can cut the gaskets and obtain seals locally but if a kit is available would rather go that way as easier. This works, but leaks transmission oil.
Thanks,
Edited by Codger - 17 May 2022 at 7:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 10:03am
I am sorry no kit for control valve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 5:49pm
Thanks kindly.
This page was generated in 0.135 seconds.
