HD11 TRACK REMOVAL
Argo2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Argo2 Quote  Post ReplyReply Direct Link To This Post Topic: HD11 TRACK REMOVAL
    Posted: 29 Jan 2012 at 10:00am
I need to remove the left track on my HD11. Is there a master link on the track and if so what am I looking for. What kind of a job (besides being heavy) is this going to be?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 12:39pm
two types of track , one with a master pin which should have a mark on end -circle or O with pin prick in center or a slight taper and a little longer than rest of pins. master link also has a shorter bushing and on inside of track link are washer and shims to take up space of shorter bushing .
 Other is a split link that the track bolts hold together and which has teeth that interlock to create a strong joint. On this type the track plate is removed and link splits in half. Bushings are same length in all links.
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 6:36pm
I have taken the track chains off and on my HD11 in one piece using an excavator and chain to do the lifting  , remove blade , remove track udjusters slide front idler right back jack track frame up a bit and remove from the side,  the master link pins take some geting out!
