HD-11 REPOWER
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 10:09pm
Just a pic from an old advertisement take with a cheapo camera phone...   Went through many sales literature pieces looking for the HD11V and couldn't find any of them.Ermm   Must have been speacial ordered. Wink LOL   Still think that machine looks real good... like them twin intakes and exhausts.
Andrew_D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 5:04pm
Originally posted by Andrew_D Andrew_D wrote:
I have an HD11S for a parts donor. I'll try to remember to get pics of any decals for you tomorrow.
Andrew
Everything is peeled, rusted, etc. Oh well, the exercise was probably good for me. (2-3' of snow still here.)
Andrew
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 7:11pm
Thanks guys for all the time and effort it is greatly appreciated. I called Fresno Tractor to see if they had parts books that might show a serial number break in the decals, will keep you posted.     Thanks again Tad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 8:09pm
Test
Edited by Tad Wicks - 03 Apr 2014 at 9:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 10:31pm
The parts book I've got lists a different decal for serials prior to 10001 vs 10001-up. Also another break pre-Jan 1966 vs Post-Jan 1966. But no pictures.
Andrew
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 1:04am
Ted, did you sell or part out the IHC 500?  I had a 500E loader for 15 years, pretty good machine, seals in the finals were the worst problem.  Sold it to a friend who has had good luck with it but only runs it a few hours per year.  I borrowed it back a few months ago to repair a damaged irrigation ditch and the bearings on one of the finals went out.  Haven't opened it up yet to see how bad the damage is, hope it's just bearings but may be looking for parts...
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 10:58am
Hi JohnCo, still got it, it hasn't moved, just as I left it, I never went back to it. Thanks for info Andrew. Tad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2014 at 8:42pm
BUMP
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2014 at 12:59pm
I couldn't help but notice in the build stage pictures, it looks like your intake to the engine is on the dirty side of the air filter. Maybe you built a custom dual element housing? I enjoy seeing these old crawlers being saved and used. Too many are being scrapped because they are just too difficult to move and transport.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2014 at 5:30pm
from what I seen on the air filter assembly is he has two filters  in the housing... one on each end of the center section...look at the weld rings...as in discoloration, they are in each side of pipe that comes out of the center...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2014 at 6:19pm
Hi guys, it is just as JC(WI) said, a dual element housing with two center dividers, I custom fabricated it all by calculating the amount of air required, two strokes require a bunch more air. There are 2 filters with internal safety filters, accessible from each side. I wanted it to fit in that particular spot and clear the exhaust, it worked out well, I just added a filter minder. I had one hole left for a gauge in the dash, I was torn between a fuel pressure gauge or a vacuum gauge, I decided on the fuel pressure and put the filter minder under the hood.. I don't have to clean them very often.    Thanks Tad
Edited by Tad Wicks - 16 Oct 2014 at 6:20pm
This page was generated in 1.297 seconds.
