HD11 Main clutch (dry type)
bottleworks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bottleworks Quote  Post ReplyReply Direct Link To This Post Topic: HD11 Main clutch (dry type)
    Posted: 13 Oct 2025 at 5:24pm
Hello!
I've been getting an HD11 back running again after sitting for 10+ years.  The main clutch between the engine and transmission will not disengage.  When the machine was parked there, it worked correctly.
I've loosened the toothed wheel A LOT (counter clockwise).  It's to the point that I'm afraid it will unscrew completely.  I just want to make sure I'm trying the right things.  I've attached a photo.  Thus far, I can't get it to break free and slip at all.  I'm afraid I'll be pulling the bellhousing.  Does anyone have the procedures on how to adjust this clutch?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 49 minutes ago at 8:19am
You could screw the adjusting ring and lock it and greace the shifting sleeve and pull back your 2 stering cluch lever and started the motor with the transmission angaged it should help
Post Options Post Options   Thanks (0) Thanks(0)   Quote bottleworks Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 42 minutes ago at 8:26am
I've done that.  At this point, the clutch lever requires virtually no pressure to move it from disengaged to engaged.  It's not slipped one bit.  I can put it in gear and start the engine and move the machine around.  I'm going to try driving it for sometime in my driveway to see if it breaks free.  I don't have the blade on it right now, so I can't try to dig into the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 35 minutes ago at 1:33pm
If you had a big rock or big tree and knock slowly
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 48 minutes ago at 9:20pm
In lieu of putting the blade back on... does it have a drawbar on it you could anchor to something really, really sturdy? Not something you'd risk pulling over onto yourself, obviously, for safety reasons... But for breaking the clutch back loose you will probably need something solid to give some resistance and get the clutch to slip free.
This page was generated in 0.053 seconds.
