Hd11 intermediate pinion cover? Missing part?
jmgeorge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmgeorge Quote  Post ReplyReply Direct Link To This Post Topic: Hd11 intermediate pinion cover? Missing part?
    Posted: 21 Sep 2018 at 7:22pm
I bought A used hd11 and it started jumping and shaking when I pushed heavier loads only, a couple hours later during one push it wasn’t steering right and started “jumping” more. Stopped the machine and noticed the cover plate to what I believe is the intermediate pinion was on the ground.
From what ican tell, this cover holds the gear in place so it engages with the main drive gear.
I noticed this plate was welded on, got new bolts and was able to get 3 bolts on it and then I welded Part of it back in place
It seemed to run fine afterwards but again during heavy loads it would jump (I think It’s jumping gears?)
I’m thinking the cover plate might be missing an internal part that secures the int. Pinion gear bearings in place and now there’s too much slip between the cover and the bearings so when it’s under load it pops it off the main gear?
I’ll have to grind the cover plate back off and remove bolts to take pics but wanted to see what people thought was the issue.
It wasn’t doing this when I bought It, all the sudden started shaking/jumping one day and then the cover fell off
Thanks for any help
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 1:44pm
The intermediate pinion cover should have 5 capscrews and some shims and a cup outer bearing and the pinion  have 2 locks gear retaining with 2 cap screws each and maybe the cap screws are gone and the gear slide on pinion and scrap the iner bearing.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 4:38pm
You can find some parts books for the HD11's at Minnpar's website, may give you a better idea of what should be there and what might be missing.
https://www.minnpar.com/manuals2.asp?FName=CRAWLER%20AND%20WHEEL%20DOZER%20MANUALS
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmgeorge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 12:38am
Thank you
I will Definitely be needing some parts then
I have The service manual But I cant Seem to find any detailed parts for under the pinion cover
How it looks under the cover now is missing most all of the metal shims, there are no outer bearings under the cover, so the pinion cone bearings are riding straight on the inside of the cover plate (probably not so good), and there seems to be a threaded bolt hole in the end of the pinion gear that caught my attention when I was Looking around in there...
I didnt Really want to spend $100+ for a parts manual so i figured I’d start here
On a fixable scale, is this a big issue? And where should I get These parts? Anyone on here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmgeorge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 1:11am
Thanks for that parts link!
So by the looks I need 3 new spacers (shims) and 1 outer cup bearing to start.
Anyone have or know where I can buy these parts?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 5:09am
Minnpar is one source for parts. Most of the AC bearing numbers in the parts catalogs can be cross referenced, or the bearing matched up if you have the old bearing. Shims can be made if you can't find any to purchased. Most industrial and bearing supply houses, as well as McMaster Carr, Grainger, MSC, etc., can get rolled shim stock in varying thicknesses, mills use it regularly making shims to set machinery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 12:42pm
I should have all these parts but you should removed the bottom final drive cover plug for drained the oil and check for small pieces metal inside maybe you will find some teeth pieces and maybe you will need to removed the complet final drive for checking and I should have all these parts.
               gemdozer@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmgeorge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 5:46pm
Thanks Everyone!
Gem, I guess I just Need the pit bearing cup and then 3 shims
I’d rather not disassemble the entire final drive, I’d really not even want to remove tracks if I can.
Hoping to put the outer cup and shims and run it and see.
I’ll email you for prices?
Thanks
