HD11 EP trains oil
baremetalworks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baremetalworks Quote  Post ReplyReply Direct Link To This Post Topic: HD11 EP trains oil
    Posted: 06 Sep 2016 at 1:18pm
Hi I'm sure this has already been covered but I cannot find a clear cut answer, I have a hd11 EP with the power shift trans and cannot find what fluid to put back in the trans? Manual calls for SAE 10? Or ATF type a, Suffix A?
What does everyone here use in these old dozers? I cannot even find anything describing an alternative. Will universal tractor hydraulic trans fluid work? or ATF?
Answers are very appreciated getting frustrated here
Thanks!
Edited by baremetalworks - 06 Sep 2016 at 1:44pm
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 2:06pm
You better use SAE 10 FOR TRANSMISSION
Post Options Post Options   Thanks (0) Thanks(0)   Quote baremetalworks Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 6:10pm
thanks finally tracked some down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 7:28am
My old 7G calls for Type A during severe cold, 10W during normal ops but I have opted for 10W all time and works fine.  Type A was whale oil ATF, no longer made, dexron took its place but was very sluggish when I used it as a test in my machine so basically used as a flush agent and refilled with 10W all season Hytran from MFA.
