HD-10 transmission fluid recommendations? |
Darkmafia1950
Joined: 24 Aug 2020 Location: Portola,CA Points: 14 |
Topic: HD-10 transmission fluid recommendations?Posted: 12 Jan 2022 at 12:18am |
Hi, I was wondering if anyone can give me some advice on what transmission fluid type they have used in their machines. 2 HD-10 manuals I have found say use SAE 90 or SAE 140. Then I found another manual that says use SAE 30 or 50 motor oil. I know I have to be picky about oil type due to the neoprene bushings and brass/copper parts used.
Joined: 11 Sep 2009 Location: illinois Points: 90897 |
Posted: 14 Jan 2022 at 6:41pm |
SAE 50 wt ..... too many addatives in gear lube
Codger
Posted: 14 Jan 2022 at 7:57pm |
Both SAE 50 engine oil, and SAE90W gear lube have the same viscosity and can be used in the gearbox and finals if a manual transmission. However with SAE90W I would only use an oil meeting the GL-4 specification. I would not use GL-5 in older units. When GL-5 first came out it was very hard on brass and soft metals due to chemical composition. I've been told this has been rectified, but GL-4 was always safe and remains safe for use in older gearboxes using brass and bronze bushings/bearings/syncronizers, etc.
