HD-10 engines?
Forestgnome View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forestgnome Quote  Post ReplyReply Direct Link To This Post Topic: HD-10 engines?
    Posted: 26 May 2011 at 3:34pm
I was looking on another site and someone mentioned most HD-10's had a Detroit engine. Mine has the Buda. Anyone know the engine history on these and when the transition was, or were they making them with both at the same time?
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 4:41pm
Has your crawler had a engine re-power ? The HD10's were made from 1940 to 1949 and had the GM (Detroit) 4/71 engine, not a Buda engine. Allis Chalmers didn't take-over Buda until the mid 1950's. The HD10 was in the same crawler series as the HD7 and the HD14. All had GM power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forestgnome Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 6:09pm
Mine's a 1958 vintage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:16pm
You sure you've got a HD10 ? According to reference books, production of the HD10 stopped in 1949. Have you got a serial number for your crawler ?
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:22pm
Forestgnome, as stated prior, it must have been a repower. 7's 10's & 14's came with the "low block" 71 series Detroit. Is your Buda a 6 cylinder with the injection in the top of the heads or the LaNova fuel cell injection on the sides of the head? this will date the engine, probably from an early HD11 is the first thing that comes to mind, and any rate it is cool to have something different. 1958 is way late for a "10", the HD9 was before that and it replaced the "10". Take a look on the right rear corner of the main chassis, you will find the serial#.
Who has more fun than people on tractors? Tad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forestgnome Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 4:05pm
That explains it. My mind is going! Mine is an HD-11. I don't know what I was thinkin.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2011 at 5:15am
Some hd11 too had  motor DETROIT 471 and BUDA and later ALLIS CHALMERS and I dismantled those 3 models.
