HD10 Engine type
Uncle Grumpy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Uncle Grumpy Quote  Post ReplyReply Direct Link To This Post Topic: HD10 Engine type
    Posted: 14 Jan 2011 at 10:09pm
Hi,
I wanted to know if the GM 4-71 used in the HD10 is the low block version or is it the later High Block?
Is there a Allis model that uses the low block?
Cheers
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 10:26am
Unsure of designation on the engine in block , as the date of this would be pre 1955 guess one could look up when the change was made.
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 9:40am
One change was on the serial number plate. Before 1947, the designation was 71, after it was A. The change from low block to high block was about then. I ain't for sure, long time ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 6:09pm
When Detroit changed the piston/rod design in the engines during the big drive to put them in trucks they changed the blocks, I believe that was in 49.  Previous to then these engines were only destined for marine and industrial applications.
