HD nomenclature |
andre grondin
Joined: 10 Nov 2009 Location: Granby , Canada Points: 1 |
Topic: HD nomenclaturePosted: 10 Nov 2009 at 9:15am |
Hi !
Can someone tell me what the "H" stands for in the HD 21 please ??? also anyone knows what the "T" would stand for TD25 International ?? regards |
Kipn
Joined: 12 Sep 2009 Location: Tewksbury, Ma Points: 800 |
Posted: 10 Nov 2009 at 9:47am |
I'm guessing as when Fiat took over Allis industrial and changed the model numbers to TL, hence, track loader. Maybe IH was the same. The H I'm guessing again was an abritary series distintion. The next reasonable letter code that wasn't used after the D series. Anybody remember the Polaroid SX70 cameras? That model number was pulled out of a hat.
Jeff Z. NY
Posted: 10 Nov 2009 at 10:07am |
I would think that when they went from gas to diesel in heavy equipment the first diesel was the HD. I would just guess the H was short for heavy equipment and the HD was for Heavy{equipment} Diesel.
I would guess.
Edited by Jeff Z. NY - 10 Nov 2009 at 2:56pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 10 Nov 2009 at 3:24pm |
The D was diesel, if you thake the industrial line H4 was gas , HD4 was diesel, same block 2200 but equiped different.
In Fiat FD is dozer FL is loader. Now that New Holland and Case are both FIAT owned unsure of how they designate .
Believe IH used TD as tractor dozer,
Why AC used H as first prefex ? As CAT was using D to prefex their machines it might have been any other letter but D, then as they had A,B,C as farm designantions, H might have been next letter in their book to use. Edited by Coke-in-MN - 10 Nov 2009 at 3:26pm |
andytutd21
Joined: 13 Sep 2009 Location: Economy IN Points: 19 |
Posted: 10 Nov 2009 at 6:16pm |
I believe the H later came to stand for Hydromatic drive, the torque converter. There is something about this in Swinford's book and "The plow Peddler" mentions that Allis allowed the automotive industry to use the Hydromatic term under their copyright.
1984 8070 ps fwa, 1969 D-21, 1965 D-21(puller), 1968 190 XT, WD-45, Gleaner L, I-40 loader, TS200 Pan, AD-3 Road Grader, 918 Backhoe, HD-4 6 way, HD-4 loader, HD-7G, HD-11, HD-21
Charles Craig
Joined: 12 Sep 2009 Location: Oro Grande CA Points: 48 |
Posted: 10 Nov 2009 at 8:30pm |
Noticed that you had a "AD3" road grader. I have a "BD3" and use it to manicure the half mile of dirt road we live on. where are you located ?. I'm in southern calif. TATA CC
Joined: 11 Sep 2009 Location: illinois Points: 90845 |
Posted: 15 Nov 2009 at 9:36am |
HD = Hydraulic Dozer ? Other post is right, after Fiat go in, FD was Fiat Dozer, FL was Fiat Loader, FG was Fiat grader.. Dont think the construction division had the same designation setup as the Farm group.
Coke-in-MN
Posted: 15 Nov 2009 at 3:36pm |
Mmm, the HD5 came as a tractor only and the blade, bucket or other attachments were built by outside contractors to fit the machine. All were straight gear machines without torque converters,
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 23 Nov 2009 at 9:12am |
I have been around HD Allis tractors my whole life and have never had positive answer to what the H was for.Always assumed the D was for diesel as with the Cat's and IH crawler tractors.In the 1930's when Cat changed there numbering system they had R2,R4,and R5 gas tractors as well as the D diesel models. Early IH crawlers were called Tracktractor 35( or what ever no. model) and the Tracktractor D35 ,the diesel model,witch I beleive was shortened to T or TD as they also had gas as well as the diesel models.
Ray |
jwal10
Joined: 12 Sep 2009 Location: Falls City Or Points: 66 |
Posted: 23 Nov 2009 at 10:09am |
Yes, IHC had the same models in tracked and wheel. T 20 and F 20, T 30 and W 30 also W 6 and T 6 or WD 6 and TD 6
M Diesel
Joined: 26 Feb 2010 Location: Las Vegas Points: 128 |
Posted: 26 Feb 2010 at 5:41pm |
Hi guys, new here.
For IH, "T" stands for TracTractor. "TD" is the diesel version of same. Gas types were the norm so no special designation other than a mark on the serial plate to denote distillate etc. An AC question. My nephew has (maybe had by now) a small AC loader, with what looks like a WD engine as a power plant complete with hood and gas tank. Any idea on the model? Gary M
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 27 Feb 2010 at 1:02pm |
If the loader looks like the one on the back of the trailer it is a Tractomotive TL-W which is based on the Allis WF. About 150-200 built in 1949-1950 with about 10 known.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 01 Mar 2010 at 12:28pm |
the IH designations are, t-6, t-9 etc=track type non-diesel; td6, td9 etc is track/diesel; same with wheel tractors, w6, w9 etc wheel-non diesel; wd9=wheel/diesel. hth, Ed.
skipwelte
Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Posted: 05 Mar 2010 at 12:15pm |
Hydralic Dozer is correct. By the time the HD5s came along they didnt change the designation. The hydralic refers to the blade lift system not the transmission. This stuff was done in the 30s and 40s when they didnt use many ag tractors, they continued the lettering system in the later machines, not like today when ya gotta have a program to keep up on model numbers!!!
M Diesel
Posted: 08 Mar 2010 at 2:51pm |
That one sure looks nice. I saw ad for a TL loader on the back of a grader. Looked awkward to use. Sorry, meant to say it is a tracked unit. Similar looking bucket (very worn), with a cage and is equipped with a reverser. Standard 3 bar loader grousers. (I'm not sure he even has it anymore, it was pretty beat 5 years ago and he let it freeze about 3 or 4 years back.) Was hoping to find pictures etc to help identify it. |
BobsAc
Joined: 14 Oct 2010 Location: Lakeside, CA Points: 19 |
Posted: 14 Oct 2010 at 6:45pm |
Good question, the number referred to the weight rating in tons.... I don't believe it had anything to do with hydraulic or dozer though, as the "HD" designation was used on all crawlers regardless of use (bare farm, cable and hydraulic dozers, etc)...
